AEC Routemaster RML eli lontoon bussi
Viesti Kirjoittaja Jarkko Antikainen » 27.02.2018 12.53
Terve!
Rakensin tällaisen:
Kyseessä on siis Revellin valmistama pienoismalli Lontoossa liikennöineestä monen tuntemasta linja - autosta pidennettynä eli RML- versiona.
Lainaus mallihistoriikkia Revellin sivuilta:
"The AEC Routemaster was presented to the public for the first time in 1954. Compared with the previous bus types the Routemaster, with its integral chassis and bodywork design, was considered to be a real innovation. The double-decker, which was mass produced from 1958, was in particular characterised by the open boarding platform on the rear left allowing quick hop on and off . At the end of the 1950s a change in regulations allowed in addition the operation of over thirty-foot long buses on only two axles. Some Routemasters were subsequently divided in the middle and a central bay inserted in the middle recognisable by square windows. The new bus type, the Routemaster Lengthened, in short RML, now had room for a total of 72 passengers. The resounding success with 15 test vehicles persuaded London Transport to order a further 500 of the RMLs, which were produced from 1965 to 1968. In the 1970s more and more RMLs were in service in central London. With the constant presence of the double-deckers, kept in the typical red, on almost all routes the image of the Routemaster as a typical symbol of London was noticeably consolidated. Not until in 2005, after almost 50 years of continuous use, was the general operation of this hallmark of London discontinued."
Re: AEC Routemaster RML eli lontoon bussi
Viesti Kirjoittaja Jarkko Antikainen » 27.02.2018 12.58
Liitteet
Viesti Kirjoittaja Jarkko Antikainen » 27.02.2018 13.18
No niin, onnistuihan se kännykällä kuvien lisääminen.
Olen monta vuotta ajatellut rakentavani tällaisen ja avannut mallin laatikon, tarkastellut satoja osia ja laittanut laatikon kannen hiljaa kiinni.
Olen siis pitänyt mallia työläänä projektina jota se kyllä olikin.
Kimmoke rakentamiseen tuli vaimolta joka ehdotti että tekisin tämän yhteiseksi 60- vuotis- synttärilahjaksi Lontoo- hulluille eli anopille ja tämän miehelle.
Eipä siinä auttanut kuin tarttua haasteeseen.
Työtä mallissa on paljon. Suosittelen tutustumaam kokoamisohjeisiin erittäin perusteellisesti ennen työn aloittamista koska malli rakentuu hyvin omanlaisella tavallaan.
Järjestelmällisyys, huolellisuus ja esim. Istuinten tekeminen sarjatyönä ovat hyviä rakentelun ohjenuoria.
Muutamia huomioita:
Ohjaamon sisuskalut ja sisäseinät liimataan ensin nippuun ja se palikka sitten liimataan valmiiseen alustaan. Tämä palikka on kertakaikkiaan saatava täsmälleen oikeaan asentoon ettei korin pintapeltien asennuksen kanssa tule ongelmia.
Helpointa on liimata valmis ohjaamon sisäosat ja sen seinien ja katon sisäpinnat käsittävä kokonaisuus paikalleen samaan aikaan kuin matkustamon alakerran etuseinän osien muodostama kokonaisuus niin saa kaiken suoraan.
Portaikon alle tulee aikataulu kehykseensä lasin alle. Tai siis pitäisi tulla mutta muuten kattavassa siirtokuva - arkissa sitä ei ole. Tein aikataulun tähän itse.
Eteen, taakse ja oven päälle tulevat 38 / Piccadilly ja asemien nimisiirtokuvat asennellaan korissa oleviin syvennyksiin joihin ne ovat liian suuret.
Niitä joutuu siis leikkelemään.
Myös maskin ritiläsiirtokuva ja british museum- siirtokuva ovat liian suuria.
Semmoisia huomiota.
Työn määrästä huolimatta tätä mallia oli kuitenkin niin mukavaa rakennella että varmasti rakennan tällaisen vielä itsellenikin.
Viesti Kirjoittaja Janne Herajärvi » 27.02.2018 17.27
Upea siitä tuli.. Raskaan kaluston mallit on tosiaan työläämpiä kuin nuo henkilöautot joten täytyy arvostaa niitä jotka näitä busseja ja rekkoja rakentaa valmiiksi ja vieläpä hienosti viimeisteltynä.. Ittellä muutama vuosi sitten aloitettu Freightliner odottaa vieläkin laatikossa uutta inspiraatiota..
Viesti Kirjoittaja Teemu Kankaanpää » 27.02.2018 18.32
On siinä kyllä tekemistä. :shock: Kauanko meni tehdä? (Jos ei lasketa sitä ihan ensimmäistä hypistelyä ja laatikon avaamista :mrgreen: )
Viesti Kirjoittaja Jarkko Antikainen » 27.02.2018 19.22
Jaa-a...
No moottori oli valmis ennen joulua, sen tekemiseen meni pari iltaa.
Sitten tuli tauko, toden teolla homma pyörähti käyntiin kaikkien osien maalaamisella tammikuun puolivälissä ja siitä asti tahti oli hyvin tiivis tähän päivään asti.
Kokonaisrakenteluaikana siis joka ilta ja viikonloppuisin myös päiväsaikaan noin 2 kk ajan.
Jos olisin itselleni tehnyt niin aikaa olisi taatusti mennyt paljon kauemmin, deadline on hyvä kannustin.
Viesti Kirjoittaja Jarkko Antikainen » 27.02.2018 21.06
Vähän vielä sekalaisia projektikuvia:
Viesti Kirjoittaja teyo » 01.03.2018 18.16
Valtava duuni on ollut, alkaa kuullostamaan jo töissä käynniltä. Eipä siinä mitään ei aika hukkaan ole mennyt työn puolesta. Käsittämätöntä miten toi pysyy mutkissa kaatumatta mutta veikkaisin kun mennään kaupungin ulkopuolelle yläkerrassa tarvitaan oksennuspusseja. Mikä mittakaava tässä on?. Itseä houkuttelisi tulostaa sopivat dekalit itse. Jenkki koulubusseja on suomessa mutta onko näitä yhtään, meinaa sopisi isommankin orkesterin keikkabussiksi.
Viesti Kirjoittaja Jarkko Antikainen » 01.03.2018 20.49
Oheisessa kuvassa korin pintapellit ovat vasta sovittelussa ilman liimaa mutta laitoin kuvan tähän siksi että siinä oleva tulitikkuaski hahmottaa mallin kokoa.
Mittakaava on 1/25.
Pituutta muistaakseni 38cm.
En ole ennen tehnyt näin suuritöistä mallia.
Painopiste näissä mahdollisimman alhaalla, rakenne on kuin lentokoneessa eli raskaan rungon päälle on rakennettu ristikkorakenne ilmeisesti teräsprofiileista.tai sitten alumiiniprofiileista. Kaikki muu on sitten pultattu kiinni tähän ristikkorakenteeaeen, korin pintapellit ovat käsitykseni mukaan alumiinia.
Viesti Kirjoittaja Jarkko Antikainen » 02.03.2018 09.10
Aika pakata bussi kuljetusta varten.
Pienen miettimisen jälkeen sidoin mallin pohjastaan teräslangoilla määrämittaiseen liimalevyn palaseen kiinni.
Näin levy ja malli sopivat nätisti muovilaatikon sisään eikä malli kolhiudu kuljetuksessa.
Liitteet
