I finally found the time to take some pictures of a model I started about a week ago.
Box contents:
The kit, obviously, has no real prototype. It includes a fuel injected M10 engine with a turbo, along with a rollbar and some strange-looking bucket seats for the interior:
My build is going to be different. I will convert the engine to a naturally aspirated one with twin Webers. The seats will probably be replaced with stock Recaros – I'll have to make them myself, using the seats from a Revell 635 as a starting point. Here you can see some other goods I have prepared for this build:
The wheels come from an Academy 635 (with different tyres), the brakes – from a Tamiya Celica, and the battery – from a Fujimi 635 (which had 2 batteries in the kit).
Here's what has been done so far:
I cut off the rear part of the underbody, including the spare wheel well. The underbody behind the rear axle must be flat, not lowering. The spare wheel well was undersized and had a completely wrong shape. The main wheel wells also had little resemblance to the real ones, so I replaced them with appropriate pieces of a Revell 635 underbody. The molded-in exhaust had to go, too, along with the front longitudinal members, which didn't match the new front body. Oh yes, the new front body – the kit was not only incorrect in this part, but it also had the tanks, wiring, coil and fuse box molded-in, so rather than removing all these pieces one by one, I chose to replace the wheelhouses and the firewall altogether, using the Academy 635 as a donor.
Considering the scale difference and the fact that the E24 is much larger than the E21, I had to trim the new front end a lot before I got it to fit inside the body.
Now I would say the front is about 60 percent complete. The white areas are made of sheet styrene and epoxy putty.
That's it for now!
